do the resisters on the fire wall fail??
84cucv1ton
New Jersey
my uncles m1008 had 24V going into the top of the relay. before i checked that i tried to start it a few times.
so i would think i cooked my glow plugs.
time for new glow plugs right?
thanks
CUCVFAN
Gunner's Mate First Class
47
Jarrettsville, MD
It'll read 24V until the key is on and the glowplugs draw current and make the resistor, well... "resist". It really needs to be checked when the plugs are on.
ssgtwright-usmc
Hawaii
They do burn out. Are you running the 12v/24v system still or has it been converted to 12v/12v?
If it has been converted to a 12v system you dont need the resistors.
The resister is basically a step down transformer to take 24 volts down to 12volts.
AJMBLAZER
Paducah, KY
If he's seeing 24v going into the relay HOPEFULLY it's still 24v. Something would be seriously wrong if they have converted it to 12v. :shock:
CCATLETT1984
Saint Clair Shores, MI
yes they can fail.
its a resistor, not a transformer. (electronics 101)
you can bypass them, but if you do you will not be able to jump your truck from another using the slave cable if the front battery is completely dead.
CCATLETT1984
if you are getting higher voltage with the glow plugs active its a sign that the plugs are bad (at least a few of them) the voltage will continue to rise as more of the plugs fail (snowball effect)
