Microsoft MSN, Live, Hotmail, Outlook email users may not be receiving emails. We are working to resolve this issue. Please add support@steelsoldiers.com to your trusted contacts.
change the bracket .bolt it on till you can take it to a frame shop to have it riveted back on .i wouldnt leave it bolted since its on the front and takes massive loads when you steer
I would leave it bolted with grade 8 bolts. The shear strength of those bolts should hold up fine. I would leave this as the weakest link (if it actually is) as it is easier to repair than a bent spindle/axle/???
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
