Engine Pre Heating Connections?
Kevin Means
Hereford, Arizona
Hi all. We'd like to install a diesel-fired hydronic engine preheater in our 1998 M1083. Ours has a stock 3116 Cat. We're looking at the various heaters, but I was wondering, where exactly do you connect the input and output hoses in the engine compartment? When preheating the engine, how does the coolant circulate through the engine block when the engine's thermostat is closed? Thanks
Kevin
Ronmar
8,100
Port angeles wa
You use one port on the thermostat block(pre-thermostat) same place where the cabin heater is fed from. You could T off the cabin heater supply port. There is a port with an Allen head plug on the side of the engine block all the way back by the transmission/bell housing on the passenger side.
since both these ports are on the pressurized side of the water pump and thermostat, i doubt you would experience any short circuit flow when the engine is running, feeding hot supply at one port and return at the other end of the engine should distribute heat thru the entire length of the engine block and head…
