Estimating production year of an M151A2
42
Rome/Italy
Were there any differences among the M151A2s according to their production years i.e., did the early A2s differ in anyway from the late A2s - visibly or otherwise? If data plates do not exist and documents do not indicate the production date, is there any other way one could estimate the production year group ( for example, 1969-72 or 72-74 or 74-79 and so on)?
dustoff34
Duck River, Tn
if my memory is correct? early a2s were made by Ford Motor Co, then the contract ended and AM General took over late 71 or 72. The Ford fenders would come up then straight out with the tear drop turn light mount. Am General come up and dips down then across to the turn light bucket bucket.
BKubu
1,256
Gaithersburg, MD
I would assume the frame is stamped, but I am not certain of that.
I have a 1971 Ford M151A2. I did not know that the fenders on my MUTT were not identical to the others on newer A2s. If anyone has pictures showing the differences, I'd appreciate seeing that.
Artillerydan
27
Phoenix, AZ
Take a few overall pictures of the vehicle and the engine compartment. Also on the horn has a data plate with a date. That will give you a close date also. But some overall pictures tell a lot of the story for the trained eye.
42
Rome/Italy
Here are some pix of the Ford M151A2 I am referring to. Did Ford produce M151A2 come with small lights below the headlights - like this one has? If not, could this be an M151A1 with A2 fenders? Or...an A2 with grille of an A1?!:roll:
Carboarius
33
Alaska/ Wyoming
Some pictures of the rear and underside would help, but it appears you have an M151A2 with a M151A1 grill. The straight underside of the front fenders does indeed indicate it is a Ford built M151A2.
hambone
508
El Dorado, Ar
Seems to be a mixed jeep, has 2 circuit breakers like A2 but has A1 front grill, windshield and looks like A1 rear panel. I see A1 tail lights, like to see pic of rear.
nattieleather
148
Cleveland, OH
Looks like you have a Ford A2 with a A1 grill. The composite lights on the fenders eliminated the need for black out marker lights in the grill. Therefore the A2 grill does not have the small black out marker lights in the grill because they are on the composite turnsignals lights. The body looks like it had some work done to it and some modifications such as the bottom of the side panels. The Axe and Shovel holds are missing on both sides and some of the footman loops seem to have disappeared. But all in all a good looking mutt.
