Exhaust pipe gaskets
panzerjunky
san diego ca
Thanks for all your help on the paint issue I had some of the high temp paint for this just wanted some info and it all worked out fine but...... Where can i find some of the replacement gaskets that go between the clamps is there a napa equivelent or some other source/
Thanks Jerry
WillWagner
3,161
Monrovia, Ca.
If you take the joints apart and make sure they are clean and smooth, you don't need the gaskets. If you want them, Memphis has them.
runk
66
Houston, TX
I used some high temp silicone repair tape (x-treme tape, but there are other brands) around the joint before I put the clamp back on. No leaks so far.
Bill W
47
Brooks,Ga
The hardest one to find is the turbo to exhaust gasket ( 1st gasket coming off the turbo), its slightly smaller then the others and no one seems to have them, I did find one on e-bay but its definetly after market and not one I'd recommend being its so flimsey
