Factory Speedo Cable routing...?
Asmoday
Los Angeles, CA
Can someone please tell me what the correct factory routing is for a factory speedo cable housing? basically from the firewall all the way to the transfer case.
I was able to find a brand new original speedo cable and housing but can't remember how it's supposed to route from the transfer case up to the firewall.
It's the exact same length as my original with the alumunum casing cover on the cable end that goes into the transfer case.
Does the cable housing actually run under the transfer case from the floor board clamp up to the speedo reduction assembly or up over the transfer case into the speedo reduction assembly?
I'm so frustrated with this thing...!
Pics or a diagram would be awesome...
Thanks!
