field chocks!!!!
powersmoke18
nj
hey guys heres another annoying question!!! I am in need of field chocks and field chock mounting brackets that attach to the frame. any help or leads would be a big help!!!
thanks sooo much!!!! Bart!!
gimpyrobb
dumpsterlandingfromorbit!
27,787
773
Cincy Ohio
I have some brandy new military ones still in the box with the chain lead on them for $20. I don't have any mounting brackets though. Let me see if I can find a pic.
powersmoke18
nj
they attach to the back of the m816 for winching heavy loads. they act as an anchor so the truck dosn't get pulled backwards. what your talking about are wheel chocks which i could also use!!!!
gimpyrobb
27,787
773
Cincy Ohio
Ahh, ground spades. I know where some are, ain't cheap though. I think $100 each. It'll be a bit B4 I get back there.
powersmoke18
nj
well i need them!! so if anyone knows of any on the east coast i will take a ride!!!! any leads on the brackets??
emr
25
landing , new jersey
Hey powersmoke, are you going to the NJ MTA ahow, ? in april...I will be posting a bunch of info soon, also sorry for asking in the thread, hope nobody minds to much, i still am to stupid to find the PM button? Thanks Randy
BKubu
1,224
Gaithersburg, MD
With regard to the mounting brackets, I've owned a few wreckers and seen many more. I've never seen two wreckers with the exact same brackets that mount the field spades. In fact, the brackets look homemade to me. They are basically just studs welded to the top of the wrecker boom that secure the field spades. Perhaps, there is a kit about which I am unaware.
Stonepicker1
104
Coconut Creek, Florida
Back in the late 80's when I was working as a Military Maintenance Tech, we made the brackets out of scrap metal and welded it to the top of the boom.
This put the spades out of the way. I can't remember them ever being used.
M813A1
OKC, Oklahoma
The spade mountand a ball type socket and should be mounted just under the body at the rear corners, on the boom and should also been at the front frame rails of the truck, the spades if I remember correctly they are about 6 foot long with a ball type end and a " C" shaped blade on the other end !! When I was in USAR, Co. A 841St Eng Bn. 2nd PLT , the unit got enough of those spades for all 12 of the Dump Truck and those spades were for use on the Wrecker truck only !! What a waste of money !! Someone read the - 10 and the Unit TO&E wrong and they bought spades and my unit did not have a wrecker only HQ unit had the wreckers !!
powersmoke18
nj
whats the nj MTA??? i go to alot of shows but this is my first military truck, i have a 1965 B61 mack truck so i attend alot of old mack shows, i also have an 800hp cummins powered ford race truck so i attend alot of diesel truck events so im sure i will be attending this MTA event if i could get some more info and if it does not interfear with any other events. as for the mounting brackets, they are something i could fabricate. think thats the route i'm gong to go on the brackets, and the brackets i was refering to are the ones mounted to the frame, when you are using the field chocks. as for the field chocks im still looking for a source!!!
thanks!!!
