filter specs
gimpyrobb
dumpsterlandingfromorbit!
27,787
773
Cincy Ohio
I had contacted some manufacturers of filters I use. I am posting in case it might help anyone.
Hastings filters FF906 and FF973 are 4 micron nominal and 15 micron absolute. Those are the primary and secondary filters for stock deuces.
I have also used Fleetguard FS1000 and FF211.
This is the specs I got from Cummins on the FS1000:
FILTRATION, MECHANICAL SPECIFICATIONS AND TEST STANDARDS
CAPACITY 72 g CECO ES14225
TERMINAL DP 7.97 in Hg
RATED FLOW 89.83 GPH
CLEAN ELEMENT DP, MAX 1 in Hg CECO ES14225
EFFICIENCY, TWA BY SAE J 1985 98.7 % SAE J1985
MICRON RATING BY SAE J 1985 10 micron SAE J1985
EFFICIENCY, TWA @ 2ND POINT BY 83 % SAE J1985
SAE J 1985
MICRON SIZE @ 2ND POINT BY 5 micron SAE J1985
SAE J 1985
EMULSIFIED WATER SEPARATION 95 % SAE J1488
FREE WATER SEPARATION 95 % SAE J1839
ELEMENT COLLAPSE/BURST, MIN 39.88 PSI CECO ES14225
HYDROSTATIC BURST, MIN 203.05 PSI ISO 4548-6
HYDR. PULSE DURABILITY, MIN 41000 Cycles CECO ES14225
AT HIGH PRESSURE 101.52 PSI
AT PULSE FREQUENCY 4 Hz
SINUSOIDAL VIBRATION, MIN 1000000 Cycles CECO ES14225
AT ACCELERATION 5.1 G's
HIGH TEMP 250 F°
LOW TEMP -45 F°
This is for the FF211:
CAPACITY 52 g SAE J905
RATED FLOW 120.21 GPH
CLEAN ELEMENT DP, MAX 1.48 in Hg SAE J905
EFFICIENCY, TWA BY SAE J 1985 97 % SAE J1985
MICRON RATING BY SAE J 1985 8 micron SAE J1985
EFFICIENCY, TWA @ 2ND POINT BY 90.4 % SAE J1985
SAE J 1985
SAE J 1985
ELEMENT COLLAPSE/BURST, MIN 79.77 PSI ISO 4020/1
HYDR. PULSE DURABILITY, MIN 50000 Cycles ISO 4548-5
SINUSOIDAL VIBRATION, MIN 10000000 Cycles ISO 4548-7
HIGH TEMP 250 F°
LOW TEMP -45 F°
gimpyrobb
27,787
773
Cincy Ohio
These are just the ones I have been useing. In contacting customer service at most filter companys, I have been emailed LOTS of specs. I mistakenly deleted the info I got from Baldwin.
