mtperkins
- 36
- 18
- Cazenovia,NY
Hello Folks,
So my wipers were not working last winter and i found a burned out fuse holder. While i was under the dash i found a accessory wire unhooked that i thought went into the fuse box. Well i plugged that in and i ended up with smoke under the hood. Unhooked it fast. Then my glow plug light would stay on while running.
Parked the truck for months before the glow plugs burned up.
Removed shorted out voltage drop that was feeding Glow Plugs 24v. Replaced the GP's.
Replaced GP relay. Wait to start light still stays on. I would unhook power to GP relay after i got the truck running.
Then the batteries would be dead. Found 5 volt short at the 24 suppressor. Removed that.
Next i hooked the GP relay back up and then tried to hook the batteries back up. SMOKE!!!! The blue wires (fuse link) at the 2 stud firewall engine terminal block melted. ( insulation only it seems)
I quickly unhooked the bat cables. unhooked the GP relay from this. Then hooked the batteries back up. Everything was fine. Hooked up GP relay. Used GP to start the truck. It ran and my stupid wait to start light was out finally.
HOWEVER!!! Now i have a 10 volt draw on the first battery.
I unhooked the GP relay and alternators. Still 10v draw.
Bash me for trying idc. But im just frustrated. What did i burn up now?
Truck is now named Smokey...
Matt
1986 CUCV
Matt
1986 CUCV
