Front mini light kit lights
vbrescueman
Dismal Swamp VA / Cochran,GA
some kind of lights in the back isn't such a bad idea. A friend of mine was catching up to me on the way to work ( at 530 am) couldn't see me but he did hear me... that flat green absorbs what little light was out ther including his headlights... just food for thought.
Doc
houdel
10
Chase, MI
Bjorn - I agree, some pics of the installation would be nice. That sounds like a good safety upgrade. From where do you power the marker lights? From the headlamp circuit, or have you repowered the front park lamps to light up whenever the headlamps are on?
On a totally unrelated note, I noticed the remote oil filter in your pic. As I recall, you mentioned the filter was plumbed up with hydraulic hose. That seems like overkill for a lube system that puts out 120 PSI max. Wouldn't high temp rubber oil line hose be a better choice, or even nylon 11 tubing?
BFR
Rocket Surgeon
2,330
42
North Georgia
I bought my truck as a cab & chassis It had them in the front(actually it had one of the mounts in the front and holes where the other one had been).
I think is makes a big difference especially on a vehicle painted a flat dark green.
cranetruck
Meadows of Dan, Virginia
Some images of the marker lights.
They are wired to the front composite light assy. Note the extra separate ground and the use of "star" washers.
I'm following through on the XM757 also.
Lee, the hydraulic hose may be on overkill at 1,250 psi, but 5 to 10x the rating is pretty normal for mil spec assemblies. If I were to keep this installed for years, rubber hoses with hose clamps wouldn't do it for me. Bottleworks decided on the hydraulic hose also.
Nylon tubing with compression fittings? Don't think so.
What are the peak pressures encountered in the oiling system anyway? I want to be on the safe side.
BTW, the "hydraulic" hoses on my crane are rated 4,000 plus psi.
jwaller
19
Columbia, SC
I thought I'd post up the pics of my clearance light install. The brackets come off bride trucks. and yes there are kits the military has to install them that come with all the wires and connectors and everything.
My truck had 1 light in the middle of the bed but I thought I'd add a few more for safety.
1,142
The internet?
jwaller
19
Columbia, SC
Ferroequinologist said:
So cranetruck, are both lights markers? I would love to do that same setup but make one a marker and the other the turnsignal.
on bjorn's truck one is a marker and one is a turn signal. I will be doing the same thing to mine with an additional plate under the current one.
