fuel pump question
jamesonsdad
queensbury,ny
good morning MV'rs i am changing my mechanical fuel pump today and being my first diesel i'm wondering when i replace the failing one is there anything else i need to due?i.e bleed injectors or anything kike that or can i start it up and go?? as always thanks to all who respond
Westech
CPL
6,104
211
cow farts, Wisconsin
you need to bleed the fuel lines.. Get the TM and it will tell you how to do so step by step. If you just try starting it you might get air in the system and that wont harm anything, it just makes it that much harder to start and bleed out.
jamesonsdad
queensbury,ny
thanx westech for the response so just bleed it trough the filter housing after changing the pump?? my comp. is not letting me download the tms for some **** reason
Westech
CPL
6,104
211
yup just bleed it at the filter.... Just like if you change the fuel filter (might not be a bad ideal to change the filter.. lots of crud can get in the lines and bits from the new pump)
jamesonsdad
queensbury,ny
i replaced the fuel filter the other day checked my check valve on the ip i think the diaphram in the mechanical pump is shot and leaking back down after sitting for a while and thanx warthog i did go to jatonkas site but my comp is a relic and wont let me download large files but hey i always have my fellow mv owners for backup and i truly appreciate it i'll let ya all know how i make out i might hva to kayak out to my m1009 though...lol.....
