Fuel System Help
Florida9
Lantana, FL
Can anyone tell me how the fuel system converts from a 1990 humvee 6.2l diesel to a 1985 m1008 and what kind of transmission bolts are for the transmission are they metric or standard??
Please and Thank You
Warthog
245
OKC, OK
What do you mean by fuel system? The Humvee injector pump uses a 24v fuel shutoff valve, where the CUCv uses a 12v. You will have to switch the solenoid.
The mechanical fuel pump is the same.
As far as the transmission bolts they are metric. Mounting and pan.
Have you download the FREE Techinal Manuals that have all of the parts listed along with the GM part numbers?
www.jatonkasm35s.com
Florida9
Lantana, FL
so i would switch the top part of the pump or replace the entire pump? and i didn't know about that site that helps out a bit thank you
Warthog
245
OKC, OK
just the top cover need to be switch, four screws and your done.
