Gamagoat engine repair TM and injector question
m561gamagoat
30
Akron/Ohio
Ok, I can't seem to find this on the forum search. What TM covers 353 repair. I used have all these but they went away with my first goat. Also, can I replace injectors without having to mess with the rack? Thanks in advance.
Jericho
70
Landaff NH
send me your Email and ill try to down load the repair manual for the engine and vehicals to you, yes if your careful
Jericho
70
Landaff NH
Ha ha ha , not laughing at you, rather with you, yup had the same, most general parts are availbe thru any detroit dealer, if you can get the civiy "read" cast iron block 353 Pn many times a good napa store can get them , there is a spring in the tensioner, many times it is corroded/ gunked up and a simple cleaning helps, if it has lost its tension source a new spring from napa
