bchesley
- 0
- 0
- Whitehouse, Texas
I have been rewiring my alternators from a previous owners debacle and now have the wiring corrected per the TM's. I was missing an isolated ground alternator so I got one from Old Mechanic and it test good. Now both alternators that tested good are installed in the truck. I turn the key on and get only a Gen 1 light. I have already replaced the relay for Gen 2 and the Voltmeter with CUCV Electric relays. I have replaced both bulbs for the Gen lights. I have also checked for power to the relays and they both kick on with the key in the run position.
My searches on the subject revealed that the order of power should be Gen 2 light bulb to the Gen 2 Relay to the Gen 2 Diode, to the Gen 2 plug. Is this correct? I am getting nothing on the brown wire at Gen 2 and want to make sure I go in the right order. Can a bad light socket really kill the alternator exciter circuit? Thanks.
Brad
Brad
