Generational Change ,,,,, Won two MEP-803A Units Today ,,,, Upgrading
storeman
52
Mathews County, VA
Won two low hour MEP-803A units today from GL Portsmouth, VA,,,, upgrading and time for a generational change ,,,,, They will replace the 002a and 003a shown in my avatar. Nothing wrong with either. Both are low hour and run like champions. One backs up the other, just in case. Both exhaust through flex out the back wall.
But we lost power for 8 hours about 10am a few days ago and ambient temp was up around 90 degrees. The shed I built about 5 years ago is pretty much a Faraday cage. Have lost power in cooler/cold weather several times since building the shed and had no problems with either genny overheating with doors open and a fan running inward. This time I ran the 003a had three 10 minute overheat shut offs with 4 fans running into the shed.
We had 5 family house guests at the time. The great discovery was that I could run 2 central air units and all utilities off the 003a without exceeding 60%. This is a big house. I must have pretty easily starting AC units (Carrier 10 years old). Gas heat and water and stove. All normal things on and water pump on. Of course no oven or clothes drier running, otherwise all normal.
I am NOT going to modify the shed... so am going to water cooled units. Will be downloading the manuals shortly. Hopefully these will be functional "out of the box", so to speak. If not, I'll be looking for advice if the manuals confound me. (Happens a lot lately.)
Will sell off the 002a in an ASK enclosure and the 003a once these are up and running. I've gotten involved in other interests the last couple of years but I'm back in a limited capacity. Its tough to be about 74 and have not enough time in your day. :D:D
Jerry
jamawieb
568
Ripley/TN
Great to have you back!!
The 803a's are easy to work on with minimal experience. I think you'll really like them over the 00a models.
jamawieb
568
Ripley/TN
Those are some nice units out of VA. One item that you might want to get before you get the units home is a roll of the fuel returns line. Since the units are low hour and been sitting a while, the fuel return lines crack and leak. There are a couple of threads about it. With real low hour units, it seems to always happen.
Guyfang
25,996
Burgkunstadt, Germany
Jerry
Jerry,
I am only 63, and have the same "problem". What's worse, is that everyone else feels like "helping" me out. Everyone has some kind of a deal I can take care of, because I have so much time on my hands!
storeman
52
Mathews County, VA
Thanks Jimmy. Your torque wrench shipped today. I'll try to find the posts. Good to be back.
Jerry
storeman
52
Mathews County, VA
Jerry,
Exactly. My best friend is my Kubota 3130. No guff and always ready to help.
eatont9999
DFW, Texas
The 803 sets are easy to work on. The most annoying part I have found is that the panels are held on with numerous nuts and screws. Kind of a pain to open it up for repairs but I plan not to have to redo work once I finish with a set.
storeman
52
Mathews County, VA
Good news guys! Fueled up and fired up both today. Started immediately and ran beautifully. Love them! Now to uninstall the two units in my shed and replace with these and sell the 002 with ASK and the 003. Can't believe the 003 still only has 80 hours on it.
They both have Peter's remote start system on them. I think I was his first SS customer. Not sure whether the remote start could work with the 803s and can't figure out how to contact Peter to determine.
Jerry :whistle:
Dwnorton1
23
Healdton Oklahoma/ SOOK
Wait until you put it back together and have to be a contortionist while standing on head while bending arm/wrist in four different directions simultaneously to try and get nut started. But its best to do load test first so you can bake cookies for kids as bribe to reach up in tight spaces, (just don't tell them where you baked cookies at, don't want to share all the time)
storeman
52
Mathews County, VA
BTW: I have 3 ten foot flex stainless exhaust pipes on my current units. They came from the laundry unit I bought about 5 years ago. It had only one MEP 003 on it (which is the one I kept) but it had 4 flex pipes. Sold one to a member. Glad I'll only need 2 for the 803s. They are same size as the exhaust outlet and thread directly on.
Jerry
gimpyrobb
dumpsterlandingfromorbit!
27,787
772
Cincy Ohio
If the new units are in the same small area, your still going to have cooling issues. Imho.
You can only cool so much with X ammount of air space.
I hope it works the way you plan, but I wouldn't hold my breath.
jamawieb
568
Ripley/TN
Jerry :whistle:
The remote starts are different for the 803a. I've installed several on 003a's and 803a's, the boards and components are different. Peters number is 913-728-2662 if you still need it.
storeman
52
Mathews County, VA
If the new units are in the same small area, your still going to have cooling issues. Imho. You can only cool so much with X ammount of air space. I hope it works the way you plan, but I wouldn't hold my breath.
I expect so Chris. I'll need to add louvers to the shed and provide fans from the convenience outlet for hot weather operation. One is a backup to the other so both will never operate simultaneously. Jerry
peapvp
1,350
Basehor, KS
Hi Jerry,
These board will work in either unit 002A/003A or 802A/803A as you had the original boards with the extra Diode across from Start Terminal to Oil Pressure Terminal - the Diode is no longer needed for the 802A/803A setup - contact me through pm for 802A/803A installation manual.
Sorry for very delayed response, but I have been very busy with other projects besides genset's
Peter
Jerry :whistle:
