Glow plugs roasted
softail97
Kentucky
Help! I installed a new set of glow plugs and started right up at 24 degrees. A few days later 48 degrees and took forever to start with a nice white smoke show lol! My glow plug light comes on as it should (no flashing). When I pull a boot from one of the glow plugs and test it, it has 24v and never tapers down like it should. Is this a smart box issue, GPC issue, voltage regulator issue or something else?? TIA!!
Coug
4,589
Olympia/WA
It is NOT a voltage regulator issue. Completely separate system.
Usually a smart box issue.
GPC just tells the smart box if the engine is warm enough to need glow plugs or not, but doesn't have any direct control over them.
softail97
Kentucky
Thx I was afraid of that😕
"My glow plug light comes on as it should (no flashing)."
Does the light ever go out, or stay on permanently?
yes the light goes out some where around 6 second.
M1165A1
889
The High Country, CO
What glow plugs did you use? The proper ones, or the Chinese ones?
Also: get a glow plug removal tool. Chances are one or several of your plugs are swelled up and won't removed easily.
softail97
Kentucky
I bought them from black dog customs.
M1165A1
889
Those are the good ones, so you can rule out cheap glow plugs. Signs point to start box.
If you decide to replace it, get the Camotek.
softail97
Kentucky
Mainsail
1,763
Puget Sound, WA
The question should be, what size wrench did you use to install them? If it was 10mm, they're cheap junk. If 3/8" then they're probably OEM.
TOBASH
3,855
Brooklyn, NY
Rebuild your box. My signature line contains the instructions. It will be much more robust afterwards.
