Good mounted holster?
Sand
25
Tampa, FL
Does anyone have any good suggestions for a mounted holster for an 87 M998? All the ones I find are magnets and that’s a no go for aluminum.
dr3d
94
Gulf Coast, Texas
Hmmm ...
If you like the magnetic design (checks remaining boxes), maybe glue or screw a strip of steel so it will work. Maybe skip the strip and use screws in place of magnets.
But, think long and hard about affixing your sidearm to your vehicle. Many states will frown on the holster - definitely not clearly legal in Texas. My personal preference is a cross draw holster for heavy driving days. This puts it exactly where I'm most likely to need to have it.
Far as good alternative, I'd screw a safariland ALS to the truck. There is a wide assortment of mounts for that holster. Just be certain to mount it so that the release button is well placed.
Sent from my SM-S908U using Tapatalk
Barney File
North Florida
I bought a "Prepcision Magnetic Gun Pistol Mount Precision Quickdraw" a few years back. They have 4 holes for screws to mount and have a concealed magnet to secure the pistol. A nice feature is you can charge an empty chamber by pushing down on the grip as you grab your weapon. Never tried it with a revolver though.
Sand
25
Tampa, FL
Where did you mount it?
FlameRed
623
Florida
I see by your avitar you are located in Florida? If so, In Florida, a firearm in a vehicle must be securely encased or not readily accessible for immediate use, unless it is concealed on your person.
So if you have it mounted in a holster and get stopped by LEO, prepare to be swatted. You can't have a firearm openly visible in Florida.
I know they just changed the law and you do not need a concealed carry permit anymore to conceal carry. But I do not believe they changed the above requirements.
98G
Former SSG
4,655
It appears you are correct. Here's the relevant information-
98G
Former SSG
4,655
And it would not have occurred to me that concealed on my person is just fine in FL, but my magnet would have been illegal.
The laws on this topic are just byzantine, deliberately designed to cause inadvertent violations.
98G
Former SSG
4,655
The magnets bolt in. The magnet holds the firearm to the magnet, not the magnet to the vehicle.
I have not yet examined the M998 for optimum mounting location. With FL law, you probably don't want a magnet.
Mainsail
1,763
Puget Sound, WA
When I was a gov quality inspector I had to take a course in Mag-Particle NDT, and they teach you to demagnetize the parts after inspection. The idea is to prevent the part from attracting grit that can cause damage later on.
Knowing that I don't use magnets. I carry in a cross-draw holster most of the time - easier access while sitting. The only place I want an off-body holster is for the motorcycle.
