Ground and neutral wires on me 003 a
marklittle
woodstock ct.
There are two wires on the back of the ground lug, one is around 6 ga and the other is around 10 ga, do I remove both and tape up so I can connect neutral and chassis ground to corresponding locations in my house panel
Scoobyshep
2,282
Florida
6awg should be the neutral and the 10awh should be the bonding jumper. I feel it's important to warn you that if this is disconnected from the house you need to reconnect that bond
Sent from my SM-S908U using Tapatalk
