dmetalmiki
- 2,034
- 113
- London England
Ok so I have my other trucks fitted with engine oil pre pressure pumps. BUT I have a post op knee and other age related things. (tripping & falling off the wrecker just to mention one!) and I was reducing my stock..well I will AFTER this newly obtained deuce!!??. So I cant believe the delay in the oil pressure delay on start up..scary..damaging..so.I do NOT relish climbing under struggling and faffing to fit another pre oiler setup. HA! "lets do it the (an) easier way. So gents for those who just drive to shows and fear pulling the sump / lack of tools n' experience. Here..(at last!) is the guide on how to fit multifuel engines with a pre-pressuriser In 2 UNDER hours. minimum fuss tooling & labour.
a/ obtain a 24 volt oil pump. b/. drain sump & replace sump plug with a fitting (iether , your choice, I used the front sump for more flow. ) c/ remove & drill oil filter can (I used the first in line) & braise or mig in a fitting. then re-fit it. d/ Mount pump as short piped as poss. (I used the chassis rail nice snug fit.) e/ fit made up pipes. f/. wire up pump to cab switch. (and / or Via a 24volt solenoid. (prevents arcing if its a rather h.d. pump)). g/. refill engine with oil, and mebb'e prime the NEW PUMP & circuit. ( I did this in assembling). Run the pump chuckling with self satisfied glee..relish INSTANT oil pressure. I am well satisfied with the ease and time taken on this fit. It suited my present medic. capabilities.
I will be fitting the M45 with the same kit. The cost total (2nd hand pump £20)
piping and fittings £60. Only came to £80. cheaper than an engine repair/replacement.
Oil changes simply require the pipe end nut undoing.
For those deeming it necesary , fabricate a neat sump gaurd / shield under.
[media]http://www.youtube.com/watch?v=__NGAkGTio8[/media]
