Hard Starting M818
Sparky11
Mount Clemens / Michigan
I have an M818 and this fall it began to take a little more cranking to get it started. It progressed to where it would not start at all; the colder weather doesn`t help, but I suspect there is something else going on. I checked the fuel and it is clean and no water. I replaced the fuel filter/water separator, no change. Then I replaced the fuel line that runs between the fuel filter and the fuel pump (on the engine that feeds the injectors). I noticed that the fuel priming pump was ineffective so I used a hand vacuum pump, this worked well. The engine started (had to use ether), but even after warming up the throttle response was poor and there was little power. I was thinking that maybe the fuel priming pump or line may be leaking and allowing air into the fuel system and acting as a vacuum break. Any ideas of what else to consider?
crasheej
Hermitage,MO
You got a line that is letting air in. Check the rubber lines at the tank slector vavle by the hand brake. Replaced the hoses on mine some time ago that fixed it
5tonman1971
Lima ohio
Check the fuel lines I almost bet it's loosing prime and sucking air we had an 818 doing the same thing and we just replaced the lines and it's fine now
1,191
Replace the primer lines too. Clean the primer check balls and seats and replace it's oring. Make it work properly.
Rebuild the tank selector valve.
joesco
Hampstead, NH
My big culprit was a crushed fuel line under the spare tire carrier. I also found leaks in and around the primer pump and filter housing.
