- 299
- 131
- 43
- Mico, Texas
Take the new nuts off and reinstall the old one until you get factory replacements. The new nuts you have are not locking nuts and will back out! Factory nuts will fight you going on and coming off. This is normal.Wanted to replace a bunch of rusty, warn lug nuts. Seems that the only lug nuts I could find 9/16" R18 thread don't fit as tight going on as what I took off. The new ones glide right on, and when I put the old ones back on, I have to use the inpact driver. Appreciate any help.View attachment 681458
I figured so......but was afraid to pull the trigger. Thank you brother!Take the new nuts off and reinstall the old one until you get factory replacements. The new nuts you have are not locking nuts and will back out! Factory nuts will fight you going on and coming off. This is normal.
.........The new nuts you have are not locking nuts and will back out! Factory nuts will fight you going on and coming off. This is normal.
........ New ones (nuts) go on easy because they have not been distorted by torquing them over the years or ratcheted down with a gun. .........
That's okay.......I usually get smart ass answers like "Well then, you should have bought an H1." But yes, little confused with contradictory answers......
What was confusing? You need locking lug nuts. The OEM nuts will nut spin on freely. Do not use an impact gun when putting them on.
What is confusing is that I am getting two different answers from two different people.....did you take the time to read all the comments?Are we talking lug nuts? They are nothing special, common gm, ford, and chrysler 3/4 & 1 ton standard threads not metric for 20 years. 7/8 hex- 9/16-18 all right thread. New ones go on easy because they have not been distorted by torquing them over the years or ratcheted down with a gun. Use a torque wrench and tighten to correct value.
Rim clamp nuts are torque to yield distorted lock nuts. Advisable not to reuse and replace.
No, These are not metric on a hmmwv. 9/16-18 right hand thread using a 7/8 hex.I was told that this is a standard Chevy size.
Here is the size as tested by a pro (not me). https://goo.gl/photos/BUZrqBSYPcXMCtfa9 M14x1.5
I haven't bought my replacement yet -- can someone confirm this size is right? I don't want to buy few dozen just to find out that they're wrong?
That size do I look for on fleaBay?No, These are not metric on a hmmwv. 9/16-18 right hand thread using a 7/8 hex.
What they are referencing is a later model GM truck not a hmmwv. These are old school.
Just tell parts guy 82 Chevy C20 3/4 ton 8 lug pick up
