Hmmwv rear wheel inside oil leak
Over
Cave Creek AZ
I have a 1989 HMMWV that the drivers side rear wheel is leaking oil. The leak is on the inside of the wheel seeping out of what I call the hat. It has 4 bolts holding it on. Can I simply loosen it, clean it and reseal?
Action
1,561
East Tennessee
steering arm cover. It looks like someone has already messed with the bolts. Maybe trying to fix this issue? Or creating the problem.
rcamacho
914
Bainbridge Island Wa
Remove.
Clean.
RTV.
Torque to spec.
Good time to inspect all bearings and retorque spindle to spec. New washer required and lube
Over
Cave Creek AZ
Thanks for the advice. This is the rear wheel but it's still a steering cap? So just unbolt, remove, clean and RTV? After a trip to Home Depo (20 miles) it leaks down the tire a bit.20180728_135829_resized.jpg
Found this YouTube video. https://www.youtube.com/watch?v=vJ0RgGWk1rU
My question is when I remove the cap should fluid come out normally? It is not normally dry in there.
NDT
7,138
Camp Wood/LC, TX
Is it the photo angle or is that part bent? Sure looks like it. If so you will need a new one. They were aluminum early production.
Over
Cave Creek AZ
Fixed the leak by pulling the cover and resealing with Permatex "The Right Stuff". Turns out one of the bolt holes is stripped. Will helicoil at a later date as it's holding up so far. Thanks for all the help!!
