how do you pull the locking hub unit out?
edpdx
80
Oregon
I have the manual. It simply says to remove it... How? I tried to grab it with needle nose'- no go.
Here is the drawing and what I have out so far. Notice the apparently broken washer(spacer) I pulled out- lay inside of the ammo can top. I didn't see one like it in the drawing?!? It is twisted- this IS broken right? I am getting new hubs- do I buy a kit of some kind with replacement parts?
porkysplace
1,496
mid- michigan
There is a wire locking on the inside of the hub .
Edit ; this thread will help you it has pictures Tire stuck . You can increase the size of this photo in post #22 of the tire stuck thread the yellow circles show the retainer ring ends that need to by pryed out.
Barrman
2,170
Giddings, Texas
Yep, you have "THE" clip to pull yet. I have had great success with a curved pointed tool that looks like a dentist should own it. The first time took close to an hour. Now, I don't even think about it and can even talk to people while I am pulling it out.
Sp0okfish
virginia
Yeah I one up the curved tool also. Don't you have to take the brake caliper off also to completly take the hub all the way apart.
Sp0okfish
virginia
Yeah that's what a thought I took both if mine all the way down because my hubs wouldn't lock in. All it was was sand in one of the hubs.
rickf
2,237
Pemberton, N.J.
If you do not have the mentioned tool a small screwdriver will pry it up to the point where you can get a medium screwdriver under it and pull it out.
Spookfish, sand in the hub would also mean sand in the wheel bearing and the axle bearing in the back of the hub.
Rick
Sp0okfish
virginia
Rick
I didn't see or feel any anywhere else. Only in the hub when I would turn it it was just real gritty.
porkysplace
1,496
mid- michigan
When was the last time the bearings were repacked ?
It should be done once a year unless you do alot of miles , off roading , and fording , then it should be done more often .
Sp0okfish
virginia
About 2-3 months ago. I try not to go off roading too much unless to pull my buddies out,or during hunting season. It is my daily driver and I use it as a work truck hauling mostly.
edpdx
80
Oregon
porkysplace, I did get it out with the help of a vice grip and two screwdrivers I used to walk it out until I could get a pick behind it. Thanks for your post and link.
