cjkeeliii
- 4
- 0
- Thomasville, GA
Does anyone know how I can clean my m1008's engine? I've heard that no high pressure water should be used. Thanks.
Spray some WD40 on and around electrical connections ( this will help repell water so there is minimal future corrosion) Also WD40 works well to losen mild layers off oil and grease. I take WD40 again and spray down all metal parts of block heavily than repeat with air hose... this leaves the engine looking shiny and corrosion free.. I know I know WD40 to shine engine, Don't knock it till you try it..
