I need M939 series belt part numbers...
goldneagle
1,210
Slidell, LA
Yes I tried to search for them. Not sure if the M809 series belts for the NHC250 are the same.
I need NAPA part numbers for all the belts for the M931 truck. Thanks in advance!
M923driver
Guntersville, AL
Not the answer you wanted, but I have a set for the M939 series, not A2. I got them with a bunch of other stuff but they are V belts and my A2 uses a serpentine one. Let me know if you want them.
goldneagle
1,210
Slidell, LA
Would you mind posting the part numbers for them? I would also be interested in an extra set. I need to get them for tomorrow or Tuesday so I can get my truck out of my friends parking lot.
Warthog
240
OKC, OK
The 800 series and the 923 series use the same engine. I would think the belts are the same.
I don't have the 900 series manuals handy but tomorrow I will lookup the part numbers in the parts TMs and see if they are the same.
juanprado
3,075
Metairie/La (N'awlins)
NHC 250 belts
Water Pump is correct as a NAPA 25-22425.
There is a vendor on ebay that sells the OE water pump belt and you will appreciate how much PIA that swap is. (search 22425 Pix fan Belt 3019061 Cummins) Their belt is NOS and wider than NAPA. I like how it fits the pulley higher and the even number of ribs on the bottom. I had ordered it as a spare but used it instead of the NAPA.
Fan clutch matched set of 25-28492
power stg matched set of 25-9480
Alt matched set of 24-7480 - Mine came with a Fractional horsepower 4L480 which is crazy to use this type of belt! Different angle and groove on the pulley.
If you are going to Slidell ask for James and tell him Juan sent ya.;)
Good luck on your storm prep:grd:
62
Riyadh, Saudi Arabia
Im still looking for the correct part number for the Air compressor belt, Power steering belt, Alternator belt, and Fan belt for the my M931A1. The non turbo charged NHC-250. Id like to be sure there isnt a different belt needed. I cant seem to find a cross over reference for the NSN numbers.
1,187
One option is to google each part number.
Here's what I found when I searched the fan belts,
END ITEM IDENTIFICATION:2320-01-050-2084; W/S: AIRBORNE MOBILE DI AIR SPT CTL (2ID), (02M JUL83) (AN/UYQ-3A); AIRCRAFT, T-39; SHIPBOARD MATERIAL HANDLING EQUIPMENT (MHE); RADAR SET, FIREFINDER (AN/TPQ-36); TRUCK DUMP, 5-TON, 6X6 (M929, M930); TRUCK, TRACTOR, 5-TON (M818, M931); TRUCK, WRECKER 5-TON (M936); TRUCK, CARGO, DROPSIDE, XLWB, 5-TON, 6X6 (M814, M927, M928); TRUCK, CARGO, DROPSIDE, 5-TON, 6X6 (M813A1, M-923, M-925); TRUCK, FIRE/CRASH P10
PERFORMANCE TYPE:STANDARD CAPACITY
CROSS-SECTIONAL SIZE:SAE 7/8
NOMINAL WIDTH:0.500 INCHES
NOMINAL EFFECTIVE OUTSIDE LENGTH:49.000 INCHES
BELT QUANTITY:2
SPECIAL FEATURES:LOW TEMPERATURE REQUIREMENT,MINUS 65 DEGREES FAHRENHEIT
MATERIAL:RUBBER BODY
STYLE DESIGNATOR:A2 COG OR NOTCHED
1,187
62
Yeah I finally found that through using google. But if you read the thread golden eagle points out that all the parts numbers in the thread are the 800 series and the M939 Series may use a different fan belt.
1,187
Yup, but I quit looking after that one. I would be more persistant, if I needed this info today.:-D
goldneagle
1,210
Slidell, LA
OK here are all the fan belt numbers for the M939 series trucks: (On some you can actually get away with one size larger or smaller in length)
ALTERNATOR= NAPA 25 7480 (need 2)
POWER STEERING= NAPA 25 9480 (need 2)
WATER PUMP= NAPA 25 22425 (need 1)
FAN BELT= NAPA 25 28492 (need 2)
COOLANT BASE= 4019
COOLANT FILTER= 4072
CANISTER OIL FILTER= 1954
Maybe the moderators can post these numbers as a STICKY...
ke5eua
41
Baton Rouge (Central), LA
COOLANT BASE= 4019
Golden, is this for the non-turbo 250? Looks like I will be doing a recovery at Camp Dodge and if I can't get a good deal on shipping it I will drive it to Baton Rouge (Zachary) with my wife following in the Prius. I already know it's missing the gen belt and I would rather just get all the belts in case. Truck in question is a 932.
