Idea for ghetto air conditioning
Napoleon_Tanerite
Warner Robins GA
Ok, so here's my plan, tell me what you think
I'm currently fabricating a new dash board, and built into it will be an AC inverter, so I can have AC power in the dash.
Right now temperature is not a factor because the heater in the Blazer is more than sufficient to keep me warm; however, the middle Georgia summer can be painful.
So what I was thinking was getting a plug in portable air conditioner to run in the cab. So long as I don't exceed the wattage of the inverter, I should be good to go, correct?
Westech
CPL
6,104
212
cow farts, Wisconsin
well will have to vent the condencer to the outside. really.... sounds like a bad idea.... too much work to make it function, and will look like trash. For 1000 bucks or less you can install a factory looking ac system.
atankersdad
15
Glen Arm Maryland
Get yourself one of the Red Dot A/C units that are floating around. They are made to keep the Hummer cool in 125 degree desert days. You can even install them on a deuce or 5 ton.
mkcoen
382
Spring Branch, TX
Your amperage is probably going to cause you problems. Running off ac invertors you can't even plug a shop flood light in without exceeding it in most cases.
I do have ODIron CUCV a/c kit for sale. $850 + shipping. That's about $150 less than retail and it's still in the box (well actually 3 boxes).
ssgtwright-usmc
Hawaii
I kinda liked the A/C unit on (Larry the Cable Guy) pickup truck in (Larry the Cable Guy, Health Inspector). House window unit in the back window of his pickup truck. Gitter done!!!!!
