Idle adjustment?
1,823
Right on top of the rack lever there is a nut and a screw. the nut locks the screw which is the idle screw. Minute adjustments make big changes.
wallew
You folks are the best. Honest. Sharing knowledge like this is WHY I come here every day.
That and I don't actually have a real life, so I can 'hang out' with people of like interests without ever leaving the comfort of my home.
THX for giving people like me a place to just hang out. jim
rdixiemiller
Olive Branch Mississipi
Of course you have a life. We are your life! Extended family maybe, although there are probably a few you wouldn't want to claim as close relatives.........
red devils dude
Ft Campbell
Polverone said:
Just for curiosity sakes, what is the correct idle rpm on the multifuel?
Is is different for turbo and N/A?
first off yes it is different for turbo and N/A
N/A idle is 650-700 rpm
turbo idle is 650-770 and the manual say's to
"Refer to injection pump identification plate for correct idle speed setting"
marksgarage2
Southampton, NJ
Just got back from my roadtest. Turned up the fuel a turn and a half and the idle to 800. Alot more bottom end and throttle response than before. By the way, I saw no loss in power going from a D turbo to a C turbo. Also the truck holds highway speeds better and really pulls on the hills at 55 mph. Very happy with my adjustments so far. Thanks for everyones help. Mark
baja_power
Marysville Ohio
did you do complete turns or flats?
1,823
Another good reason to keep the idle up a bit is headlights. The harmonics produced in the 600 to 750 range are heck in headlight filaments and these aren't cheap headlights.
