Information for a M-923
merphie1
Oklahoma, USA
So i recently bought a 1984 5-ton am general. Tag says its a cargo M-923 6X6
My first issue is i have no idea what engine this truck has, i can tell its a Cummins but the ID plate is gone.
is there anywhere i can find oht what motor, and where to get more info, like a parts diagram? I know i have a transmission leak and a leaking hub seal
jcollings
422
Jupiter/FL
Should be a TM on the main website. if you look under the 5 ton column.
Sent from my SM-G975U using Tapatalk
jcollings
422
Jupiter/FL
You can look and review the different TMs, pretty sure the M923 did not have ABS, and CTIS system,
Pretty sure the 250 is a 16 liter, but I might stand corrected.
You can just open them up and look at the different ones and if it looks like yours that would be a good way to go.
Maybe somebody else will chime in with that truck.
Good luck
