Injection pump oil lines
gimpyrobb
dumpsterlandingfromorbit!
27,787
773
Cincy Ohio
Myself and another are going to get some new oil lines made for the IP. Anyone in need or interested? No idea on cost yet, as usual, more than one gets cheaper. Just wondering. Post up if there is interest.
1,187
I think everyone should want one, to replace their existing flexible hose. at 40 years old, that hose has served it's term and deserves to be replaced. If it blows, your done fast.
It might be a good idea to simply do an NSN search and find a gov supplier for the hose, and request a batch.
Maybe a big group buy deal?
Westech
CPL
6,104
210
cow farts, Wisconsin
The oil lines are in..... I have the Heavy duty ones (rated for over 3000 PSI) that are ready to ship right now at $45.00 with shipping (see picture) and a "stock" line rated for 300 PSI $35.00 with shipping will be ready in two weeks.
The Difference in the two, is the heavy duty lines have a double wall 3275 PSI hose with steel braiding and 3500 PSI ends
The stock lines are a reinforced textile braid & covered with a black synthetic cover, 300 PSI working and 1000 burst pressure. Brass fittings and crimp ferrules.
Westech
CPL
6,104
210
well with shipping I am still cheaper for the stock lines.. and there 100 times better then the NOS or "factory" lines. The Heavy duty lines are way over kill but thats what its all about.
So.... If you want to spend more on the same junk that is in there go for it Mr. Hnrsonj.
SCSG-G4
PSVB 3003
5,393
3,462
Lexington, South Carolina
Since NOS stands for "New, Old Stock" we have no idea how long a particular item has been on the shelf, or what conditions it's been stored under. A brand new part is exactly that - new!
hndrsonj
Senior Chief/Moderator
365
Cheyenne, WY
Well I ordered both lines for my dropside yesterday ($16.80 and $15.90). I also had other stuff in my order so the shipping was basically no cost. I figure it has worked for 60 years so I don't need to multiply the pressure capacity ten fold. Anyone else check out clark trucks or contact one of the Military suppliers for a group buy.
http://www.integratedpartssystems.com/mmCTP/Images/00-081-4212.jpg
Westech
CPL
6,104
210
I see now that it has been posted that I am having them made and yes making $4.37 a set (the cost of 1.2 gallons of fuel for my driving to the shop and PO) there is a problem. This post has been up for weeks and not a peep out of your group. I get it. Look if you don't want them don't buy them... I offered two styles and both are over kill. Am I making money off members? well for the 5 miles to the shop, and one to the PO and the 6 back... no i am not.
hndrsonj
365
Cheyenne, WY
Westy, I only ordered mine because I thought it was a good idea when I saw them (ordering something else). I didn't even see this post till tonight. I have not looked at what they really go for. I do know saturn got $6.50 for them before they ran out. Can only imagine I overpaid.
DeuceDad
Nixa, MO.
Been there, Done that
All, I recently went through this IP oil hose change and documented it in a post back on 12-09-2010 'Newbie Seeking Help - Leaks'. I too had a hose made locally which looked just like the picture in this post (I had the hose coming off the engine block to the IP made.). After spending DAYS trying to install the locally made hose I finally concluded there was just enough difference in the starting of the threads in the coupler going to the IP that it was preventing the hose from going on. Everything seemed exact except for the slight variation in the starting point of the threads when comparing the aluminum coupler to the brass coupler. I finally contacted John at Memphis Equipment and had him make me two hoses (one to replace the hose coming off the block and one to replace the hose running fwd and aft on the bottom of the IP.). After receiving the hoses, I had them installed in less than an hour. Take my advice, purchase them from someone who has been fabricating them for 30 + years and be done with it. :wink:
Just my two cents worth..
JasonS
199
Eastern SD
Not to detract from what Westech has done...
There was a thread in SS detailing how you could make these lines using push-lock hose and fittinngs from NAPA, Fastenal, etc for reasonably cheap. I made these lines and I think that I was in it for ~$20 total.
Westech
CPL
6,104
210
Forget it. I am sorry to anyone who wanted them but it looks like everyone has a better idea. Last time I try to help anyone. I have a pile of lines and I will keep them to myself.
JasonS
199
Eastern SD
Working in R&D, I can sympathize. It can be REALLY hard to come up with a new product for which there is a market AND one where you can make any money. If it really is a good idea, most likely somebody has beat you to it or is already in process to do it. It also seems like the SS group rallys around something new but scatters when it comes time to take the checkbook out.
IMHO, what the market really wants is a reasonably low cost, bolt in hydraulic power steering.
Flyingvan911
158
Kansas City, MO
That sucks. I am still planning on buying one of your spin-on conversion kits sometime soon.
