Is there a TM for mounting antennas on M939 series?
jonesal
Mission Specialist
69
Brookings, SD
Carnac is correct. It's TB 11-5820-890-20-71, INSTALLATION INSTRUCTIONS FOR INSTALLATION KIT, ELECTRONIC EQUIPMENT MK-2378/VRC (NSN 5895-01-225-0518) (EIC: N/A) TO PERMIT INSTALLATION OF RADIO SET AN/VRC-87/88/90 SERIES IN M923, M924, M925, M926, M927, M928, M931, M932, M933 AND M936 TRUCK, 5-TON. Google for a pdf of it.
Al Jones
M923
1 Patriot-of-many
87
Zimmerman MN
Also the pass side at the front edge on the side of the cargo bed as shown in this thread
http://www.steelsoldiers.com/showthread.php?124046-NOS-Sugar-Scoop-and-Stand-Off-Bracket
If you have bows & cover then move the bracket DOWN to the bottom edge (that way the cargo cover can hang down properly and not be bunched up when installed on the truck...I know this as I need to re-mount one of mine to the lower edge!)
I put one of them on the drivers side of my deuce. Deciding where to put it on my M923, It's got all the holes for the fender, but I don't have the complete fender mount, missing the support bracket.
MtnSnow
15
NSL, UT
Here is where the base/riser mounting plate was installed on my M925a2 by the unit that had it and is where I will be moving mine on my M923a2 to match so it wont have as much interference with my cover.
Artisan
227
CDA Idaho
I believe in the TM's you can see pics,
there is a bed mount too. I made a custom mount I sell
for the front fender. Just pop some holes and Viola!
it is very stout when installed correctly.
Click HERE and then HERE for alternate views.
it looks BaddAzz!
