Is there any use for this????
LanceRobson
220
Pinnacle, Stokes County, NC
Bob, I'm not so sure that's for commo. Can you post a clear close up of one of the ends? Also, there a sleeve over the cable, what does it state? If you look at the side of the cable it should be imprinted with a conductor gauge and count (such as 6/4). Sometimes there is just a manufacturer and part number of trademark name. Is there a DLA contract number or other date on the tag? If there is a DLA contract number the 7th and 8th characters ID the year in which the contract was let. That could help.
With two visible conductors it sure looks like a prime power cable, either DC or pre ground wire days.
What is all that info?
Lance
gunboy1656
24
Beaver Falls, PA
It is CX11230. 1/4 mile cable. PITA to move around. I used it for too many years.
I like the "A" frame your is sitting on, ours had a hand screw on top that would get lost, strip the thread, whatever it could do to make it hard to use.
RJM27
30
Burdett NY
Lance
No it's def, comm wire, I believe this is what it might hook into.
Part B. Cable Assembly CX-11230( )/G
