Is this the correct transmission?
NDT
7,522
Camp Wood/LC, TX
Agree, transmission is not for your Jeep or should I say Jeep salad. I see a M38A1 body on a CJ-2 frame.
Lonesome715
25
Columbus, GA
Any idea what the transmission is? Will in not bolt up and work at all? If I am already dealing with a soup sandwich I am not all that concerned about it being"correct" as long as I can get it to work.
Unless... I can find a better option for $100. That is how much he wants with transfer case.
porkysplace
1,496
mid- michigan
The transmission he has has a driveshaft yoke hang off it , so that indicates it was from a full size pickup with a divorced transfer case . It is unlikely you can adapt that transmission and transfer case and if you could it won't be cheap.
gringeltaube
Staff Member
2,695
Montevideo/Uruguay
The transmission he has has a driveshaft yoke hang off it , so that indicates it was from a full size pickup with a divorced transfer case . .
That is not correct. What we see is the yoke on the end of what seems to be a DANA 20 T-Case, which is not divorced.
The only problem I see is with the rear driveshaft, connecting a straight-through TC with a rear differential which is offset to the pass. side.
porkysplace
1,496
mid- michigan
It a bad picture to work with .
