UT Jerry Can Replacement Straps (13 different colors available)
Valence
612
Davis County, UT
I make these myself.
$18.00 each + shipping
Located in Kaysville, UT
Newly manufactured from 100% mil-spec parts. These straps are designed to replace the oft missing, damaged, or sun rotten straps on military surplus or civilian aftermarket jerry can or fuel/water can mounting trays. Not intended for life safety devices.
Features:
  • 53″ long strap.
  • 1-1/2″ wide mil-spec, nylon or cotton webbing.
  • Available in 13 different webbing colors:
  • A-A-55301: Olive Drab (OD7), Dark Green, Coyote, Brown Sand, Sage (Air Force Green), Black
    • Nylon
    • Type VI, ~0.050″ thick, 1500 lb breaking strength webbing
  • MIL-W-17337: Camo Green 483, Tan 499, Foliage, Red, White
    • Nylon
    • ~0.043″ thick, 1800 lb breaking strength webbing
  • MIL-W-43638: Vintage Olive Drab (OD7), Natural color Cotton
    • Cotton & Fortisan
    • Type II, ~0.095″ thick, 1200 lb breaking strength webbing
    • Low stretch
    • Mildew resistant & water repellent treated.
  • Black coated, solid brass tip, genuine mil-spec, meets MS51926B-5.
  • Matte black spring buckle clamp, genuine mil-spec, meets MS51929A-3.
  • Heavy, visible outdoor polyester or nylon stitching, UV resistant, anti-wick.
  • Also includes your choice of colored elastic to hold down the extra strap “tail”. Add a little accent to your functionality!
    • Choose between Black, Gray, Tan 499, Coyote, or Camo Green.
Made in the U.S.A. with new and military surplus 100% mil-spec parts.
NOTE: I do not certify nor guarantee assembled breaking strength. Webbing specifications provided for informational use only. Not intended as seat belts or life safety devices.
  • 55301 Olive Drab (OD7) Nylon
  • 43638 Olive Drab (OD7) Cotton (NEW!)
  • 55301 Dark Green Nylon
  • 17337 Camo Green 483 (NEW!)
jerry_can_strap_od7_nylon.jpg jerry_can_strap_od7_cotton.jpg jerry_can_strap_dk_green.jpg jerry_can_strap_camo_green.jpg
For best performance, please ensure your strap is installed properly!
Valence
612
Davis County, UT
The other available variations: :
  • 55301 Coyote (NEW!)
  • 55301 Brown Sand Nylon
  • 17337 Tan 499 Nylon
  • 43638 Natural Cotton
  • 55301 Foliage Nylon
  • 55301 Sage (Air Force Green) Nylon
  • 17337 Red Nylon
  • 17337 White Nylon
  • 55301 Black Nylon
jerry_can_strap_coyote.jpg jerry_can_strap_brown_sand.jpg jerry_can_strap_tan_499.jpg
jerry_can_strap_nat_cotton.jpg jerry_can_strap_foliage.jpg jerry_can_strap_sage.jpg
