Just Got My Deuce!!!! Brake Problems
rpollitt01
Winchester, Ohio
It had been sitting for almost two years but fired right up! The brakes wont work. Im going to add the remote resiviour kit and bleed them. Any other suggestions?
Thanks for the help!
Ryan
scoutmanadam
richland, washington
replace every rubber or wearable part of the braked, get new or rebuilt wheel cylinders, new rubber lines, check your air pack and master cylinder. check all springs and pads as well as the drums. just remember, the pedal only has to go to the floor once and then nightmare time
rpollitt01
Winchester, Ohio
Gimpy, I need a service manual. do you have one available or can you tell me where to pick one up?
Are they available in the internet?
I know I can buy one line but need one this weekend.
gimpyrobb
dumpsterlandingfromorbit!
27,787
773
Cincy Ohio
I have a manual on cd I can copy for you. Most of this stuff has been memorized so I don't use the book too much any more. Might be up at creekside Friday if you want to stop out, I'll try to have a copy of the disk for you. I should be there around noon.
