Leaky fuel pump
Ryan123
Brighton, Colorado
Hey guys My fuel pump on my 1970 am gen m35A2 seems to have a small leak (nothing major) just enough to kind of be annoying.
I haven't tore into it yet just wondering if there is anyone on here that has. It's probably just a shot o-ring i would assume?
any input is greatly appreciated
DieselBob
15
Arnold Maryland
Check out TM 9-2910-226-34 for the injection pump. It will give you a good working understanding of how the pump works and where the seals and "O" rings are located on the different assemblies. If it is coming from the fuel shutoff rod assembly I would think it is most likely from a bad “O” ring on the fuel control lever assembly or a bad cover gasket.
welldigger
Benton LA
If oil is coming out yes. If fuel is coming out then its either the fuel control rod o ring or one of the HH o rings leaking.
