Lights, Signals, and Horn works
Rebelpride
Thomasville, NC
I'm installing one of OD Irons fuel pumps on my truck, I am to the point of wiring it in, but I have no power to the fuel pump wires, the gauges are dead, the low air buzzer doesn't work and the starter wont turn over. I have head lights, turn signals, and horn. My tail lights are unhooked because I switched them with my other truck. Looked in the TM briefly. Isn't there a fuse or fuse panel/box somewhere?
jfnemt1ff1
Higgins Lake Mi.
I think that there is a breaker ON the firewall under the hood on the driver side at the top.
John
Rebelpride
Thomasville, NC
I found the problem, I had a wire burn in half or something. New question, I thought that the manual would tell me which tag number went in which hole, so I didn't bother to mark them other than the tag that is on the wire now. So can anyone tell me which plug goes where or are the tags numbered 11,12,13,14?
kendelrio
9,438
Alexandria, La
You may need to find out why the wire burned before you replace it.
Very good advice. As far as the plugs go, do you mean on the light side or switch side? If it'scon the light side, if I don't mark them, I experiment until it's right..... Kind of a pain in the rear if you are by yourself. Have someone in the cab switching the lights on and off.....
Rebelpride
Thomasville, NC
I think it burned because the switch was ON when I hooked the batteries back up.(think a kid was in it playing) The top leaks bad so I'm not sure if it burnt, corroded, or was chewed.
