Loading requirements for a Government Auction
still-a-truckin
Canton, Michigan
When it says buyer loads for an auction does that mean I have to bring a semi with a lowboy or if the truck run/drives can i drive it out of the yard? Please respond!
On a lot where no help is avalible and it says no Gl personel on site!
Also in some auctions it doesnt even say if buyer loads what would this mean?
stumps
12
Maryland
GL's official policy is you may not drive a truck off of the base. That doesn't mean that many of the bases don't allow drive offs, but rather that GL doesn't want any liability should something happen.
If it says buyer loads, that means there will be nothing and nobody there to help you. None of the infamous GL forklifts, nothing. It is all up to you.
-Chuck (clearly an expert because I won and "loaded" one truck ;-)
jwaller
19
Columbia, SC
you can drive it off base.
you just can't drive it off the GL lot. it must be towed out of their fenced area. base doesn't care what you do till they pull you over for no tags or insurance.
Chief_919
103
Western NC
Unless your state will give you a transporter tag, or you can get a temporary permit for a vehicle that you do not have a title for, it is not legal to just drive off, and you are opening yourself up for legal problems.
Plus, you are buying a 100% unknown truck that you cannot test drive and have zero idea of the history on, that has likely been sitting mostly unused for many months and possibly had a number of bad parts swapped on to it before it was sold. If it is a CUCV or smaller, you can likely get away with driving it. Anything bigger and the risks go higher.
My .02- have it towed at least off post to a place where you can give it a good service before trying to drive further. Lots of people drive them off, yes. But they are accepting a risk every time. Are you ready for when the brakes fail, or the front wheel, brake drum and hub come off at 55 on the interstate and roll into oncoming traffic, or when the oil line goes and your engine blows, and the resulting oil spill on the highway causes people behind you to wreck, or when the tires shred and toss rubber all over the motorcycle that was passing you.
I have seen all of the above happen- on trucks that were currently in service. A truck you buy will be even riskier. In a normal drive, you can chalk it up to "stuff happens" and your insurance will cover. But if you just picked up a salvage truck and drove it off post without checking it, without registration or tags, and without even having a title in hand, any abulance chasing lawyer will have a field day with you in court, and your insurance company may decline to cover the damages or may pay out and then sue you.
Are you willing to risk losing all you own in court to save a hauling bill?
My .02. Many here will disagree, and will tell you tales of how many trucks they have driven home. But it only takes one going wrong to ruin your life and cause many headaches for our hobby. Take a moment to seriously consider the risks.
Myself? I will drag a trailer home after I check it out, or I will maybe drive a CUCV after a detailed check (but a CUCV would be more likely to get towbared home). Anything bigger is either being hauled home or taken off post where I can work on it, verify all is well, and do short test drives before I commit to several hundred miles home.
