Looking for o rings for fuel leak in injection pump on a M35A2.
Pa Well Driller
Sligo Pennsylvania
I have a 1970 M35A2 that is making oil. I did the FDC bypass then pulled the cover with the shut off cable and can see fuel dripping from the shaft while the electric fuel pump is running. I would like to find the gasket for that cover and o ring for that shaft and also the o rings associated with the hydraulic head, and any parts/seals needed for the mechanical fuel pump , should I need to go deeper. Thanks in advance for any direction on obtaining these parts.
cattlerepairman
3,451
NORTH (Canada)
For the shutoff cover gasket (the metallized one) you are looking for part 5330-00-419-9467. Vendors such as Big Mike have this. That very same vendor also has a 3 o-ring kit that is exactly for what you want them for on the hydraulic head and the shutoff.
