Lug nuts for rear with super single???
Hooty481
Russell County Kentucky
what kind of lug nut configuration are people running with the hemmtt wheels with the bolt in plate on the rear of their Deuce.
I put a washer on the stud so the lug nut wouldn't bottom out then the bud nut. then the wheel and then the outter lug nut. I was just wondering if anybody had done this before or if i was the only dumbass to try it.
gimpyrobb
dumpsterlandingfromorbit!
27,791
791
Cincy Ohio
What purpose does the washer serve? Is it on the stud or bud nut? You want to make sure the back of the wheel and the drum are flat against eachother so you don't snap your wheel studs. If the washer is between the wheel and the drum, TAKE IT OFF!
KsM715
142
St George Ks
Gimp is right. Take the washer off, dont use the thimble (budd nut) and get the same lugnut that is used on the front.
gimpyrobb
27,791
791
Cincy Ohio
Nah, I've been using the bud nuts to hold my rear tire/rim on for a long time. Just remove the washer.
KsM715
142
St George Ks
Sorry gimpyrobb, I was thinking putting the thimble on first then the wheel then the lugnut. (like some have been doing on the fronts). You are correct, wheel then budd nut will work just fine.
Gimp, how many times have you had someone (non-MV owner) ask you how your wheels stay on with out a lugnut? :razz:
