Jericho
- 70
- 48
- Landaff NH
Heres a head scratcher, iam at a stop here. Recovering a 2014 rebuild 931A2 tractor and attached fuel tanker, Tanker is new never even had fuel in it Tractor has set since 2016 with the trailer attached , Got it running, wasn't too bad! runs nice, pulled tractor and trailer ahead 100 feet or so, all indications were good, Trailer took air well Wheels released and came forward with ease. Let it idle for half hour or so, Was recovering another M 931 with attached flat bed trailer as well.
went to pull out with fuel tanker and trailer brakes are locked tight all tires. Checked all the normal culprits. Air pressure in cab is good, Air load is applied to trailer, Trolly brake handle is UP, no leaks on either side of brakes, Disconnected checked each connection point no leaks , good air! Loaded, unloaded air on trailer valve numerous times, Depressed brake pedal , tried every thing I could think of. Has to be a valve. ANY IDEAS GUYS. thanks up front for your time and experience
