M1008 alternator wiring problems
Joseph48
Clyde,Ny
Hi i have a m1008 and I just put two new alternators and after putting both in and started to put cable on front battery there was smoke coming off a block next to the brake booster not sure what's wrong first time have a vehicle with 24v system
MarcusOReallyus
819
Virginia
Not sure just regular 100amp alternators
There's your problem. The right one MUST be an isolated ground unit, or you get smoke. You won't get one from your regular parts house.
You can read about it here and here. There is also a lot of good info in the Helpful Threads sticky.
Now that you have smoked things, you'll have to find out what got damaged. It's likely you fried one or more of the fusible links, and you might have fried the alternator, too. You can read about testing it here. Again, you'll find a ton of info in the Helpful Threads.
Rebuilding the alternator is not a difficult job. Member TOW4 sells rebuild kits and can answer any questions you may have about it. He can guide you to what you need to make your unit into an isolated ground.
Took me about 45 minutes when I did it the first time, and I had never done one before.
Welcome aboard! (y)
