m1008 on WMO
Iceman3005
97
Holt, MI
I just started to run WMO in one of my cucv's, I have about 80 gallons of wmo that I filtered through a 5 micron filter into on of the 250 gallon tank I have. My fuel tank was about half full of diesel fuel, yesterday I topped it of with the filtered WMO, so the mix should be about 50/50. Truck had a hard time starting this morning, it was only 45 degrees out, but it did start really easy after work at about 75 degrees. going to try a 70% WMO Saturday after work. Smokes a lot at an idle but mostly clears up when cruising down the road.
islandguydon
787
Michigan
Hey Jonesville, are you running a 6.2...? The most I ever added was 5 gallons to the 15 of diesel fuel. I had to run that out on a road trip there was to much smoke and the truck was a hard start after the experiment. I went back to a quart of oil per tank. Good luck.
73m819
327
gainesville, ga.
REMEMBER that the Ip IS NOT like a multi ip whers you can run CRAP though it, you could end up with a ONE mission truck (a true wheel chock)
