M1008 Wiring smoking
84cucv1ton
New Jersey
Been trying to get this thing going. I realize the wiring was messed with a lot. Lots of splices. I cleaned a few the grounds, new starter and new batteries. The ground strap from the cab to the block cooked and is almost into 2 pieces. Going to clean the rest the connections and grounds in the morning. Thought I would ask is anything else I should look at. Have a good one guys
goldneagle
1,466
Slidell, LA
Make sure you do not eliminate the fusible links. Check the TM for wiring diagrams and make sure the fusible links are intact. Otherwise they can be replaced. Parts available on internet or NAPA.
dependable
188
Tisbury, Massachusetts
If you can buy a new engine compartment harness from one of the vendors here (Hillbilliywizzard comes to mind), it might save you some grief. Hard to undo hacking, splicing and burning. If it went beyond fusible links, or they were already by passed, a burnt wire in harness can melt into others. Almost easier to make a new harness than chase it down at that point, but you should be able to buy one.
84cucv1ton
New Jersey
Was not that bad. Was not as bad as I thought. I already have it done. Started to clean up some the other wires and connections and all the grounds. See how that Does by me
