M1008 wont start
NDT
7,137
Camp Wood/LC, TX
Check all the battery cable connections for heating. Especially the buss bar on the firewall.
Macmatrix
MI
I did notice that the battery cables were heating up. I had both of the old batteries load tested, one good and one bad. I replaced the bad one.
MarcusOReallyus
819
Virginia
Check your grounds, especially the big ground strap to the block. Clean the connections.
But.... since the voltage is low, it IS going to turn over slowly. You might have something draining your batteries. Sometimes an alternator can do that. You can test that by charging your batteries to full charge, then disconnecting your alternators (the plug in the back). Let it sit and see if the batteries hold their charge. You should disconnect the batteries before you charge them, and reconnect them AFTER they are fully charged and the alts are disconnected.
If it turns out to be an alternator that is draining your batteries, you can easily rebuild them. The complete parts kit is in the $40 neighborhood, and it's an easy job.
MuleMac01
Military vehicle collector
194
Las Vegas Nevada
Have the battery's load tested just because a battery reads 12 volts doesn't mean it will have the cranking amps. Just FYI having the starter crank slow will damage the starter.
porkysplace
1,494
mid- michigan
Starter could be getting bad , cables could be corroded under the insulation .
TM 9-2320-289-20
Table 2-3. Mechanical Troubleshooting
ENGINE
ENGINE WILL NOT CRANK
Step 1.
See Electrical Troubleshooting malfunction #42.
If engine still will not crank, notify your supervisor.
SLOW CRANKING OR UNUSUAL NOISE DURING CRANKING
Step 1.
Check starter mounting bolts for looseness.
Tighten any loose mounting bolts to 33 Ib.-ft. (45 N•m).
Step 2.
Check clearance between starter pinion tooth and flywheel. (See paragraph 4-5,
INSTALLATION)
Step 3.
Inspect flywheel ring gear for chipped or damaged teeth. (See paragraph 4-5,
INSTALLATION)
If chipped or damaged teeth are found, notify your supervisor.
CRANKS BUT WILL NOT START
Step 1.
Check to see if there is fuel in tank. Add fuel if empty.
Step 2.
Check fuel supply and return lines for restrictions, looseness, or damage.
Tighten or replace if damaged. (See paragraph 3-13 or 3-14)
Step 3.
Inspect fuel filter, fuel pump, and injector pump for leakage.
Notify your supervisor if injector pump is leaking. Replace other leaking
components. (See paragraphs 3-10 and 3-17)
Step 4.
Check for inoperative glow plugs and glow plug system. (See
Electrica
l
2-39
MuleMac01
194
Las Vegas Nevada
Ya it's most likely the starter, My M1009 had the same issue of the starter going slow after 2 new 6TL's got installed in it. Had the starter rebuilt and fixed it right up. I would have it tested.
dmetalmiki
2,033
London England
This might sound simplistic, but CLEAN your battery terminals, both the posts and the cable clamps. Battery leads heating up is a sign of BAD contact.
rsh4364
15
greensprings ,ohio
Also make sure your cable size is up to snuff,when I got my 1009 I had some 8ga.cables and 6ga. cables on it,and those really cheap steel band type batt. terminals.
Sergeant1983
Memphis TN
I bought a new starter for a similar problem, but discovered a bad connection on the firewall TB was the culprit before it came in. So now I have a new starter in my spare parts box. You really have to keep an eye on all those battery connections.
