M1009 trailer wiring harness to standard civilian trailer harness
danewerle
janesville,wi
Does anyone make a trailer harness adapter for my M1009 recepticle on the rear bumper that allows a hook up to a 4-Flat Trailer End Connector on my boat trailer.
Warthog
240
OKC, OK
Look at the threads listed at the bottom of the page. Your answer may be there.
danewerle
janesville,wi
Dr Porkchop, that looks exactly what I need. I'm assuming you got the receptacle (male end) of a military trailer and conveted it to a 4 flat connector? One more question, my truck is still a 24 volt system but I believe all the lights/signals (stop, turn,head/parking) are all 12 volts correct? Thanks
Evil Dr. Porkchop
315
Colchester, VT
That is exactly what I did. You are correct about the lighting on the CUCVs, no mods other than the wiring adapter are needed to tow a 12v trailer.
ssdvc
640
CT
I used the trailer connector. cut down the wire and traced stuff out. I connected a 7 pin, then used an adapter for the 4 pin hook up. Now I can hook up any city trailer as well as the normal mil spec trailers. Works great and it was fairly easy to accomplish !!!
