M1009 transfer case fluid
galeo7171
12
Cumming, Ga
I know ATF fluid is supposed be used in the np208. I noticed a small leak coming front the transfer case skid plate and it was gear lube. I guess the police department that I got the truck from put the wrong stuff in. Should I get it out ASAP and replace it with ATF? I've also go to figure out where the leak is coming from, I do know its not the rear shaft seal.
martindc1
La Crosse, WI
Yes I would change the fluid, its not like its expensive or hard to do. Just make sure you can remove the fill plug before you remove the drain plug. As far as the leak goes, look to see if it is leaking where the two halves of the case bolt together. Thats a fairly common leak point for the NP208 and if it gets to the point where you can't stand it any longer you will have to pull the transfer case, split it, clean the mating surfaces and reseal it with a good sealant compound.
JamieM1009
UK
Hey
my m1009 has developed a similar leak. I've only had a quick look but it appears to be coming from the front output shaft seal. Should be easy enough to fix and I don't think it takes long. I did notice that the rear one weeps a little bit so I'll do that as soon as I get chance.
o1951
155
Bergen County, NJ
Note - putting gear oil in transfer case is an old trick to quiet a noisey one needing repairs. Usually to sell to unsuspecting buyer.
When you flush it and put ATF back, you may find it is noisey. -? or someone made a mistake - drained ATF and did not notice was not gear oil??
