M1028 dually tires
319cssb
221
Easley SC
Has anyone tried to mount hmmwv tires on a dually? Is it possible without doing major changes? Would you need a spacer on the rear tires? I would like to keep it as a dually set up.
How could that work out?
LT67
513
Bowdon, GA
For starters you would need 16.5 diameter dually wheels.... and yes spacers will be needed.
A Toyo MT 255 85 16 should fit with no spacers and they measure every bit of 33.5in tall.
319cssb
221
Easley SC
I may not have been clear. I want to use HMMWV tires on 16.5 rims. Has anyone managed to put these on a 1028 dually?
Is there actually a truck that uses 16.5 dually wheels?
Curtisje
697
Okinawa, Japan
I have hmmwv tires on my 1028A3. You need 16.5 dually wheels with a 4.5 inch diameter bore. I made the mistake of getting wheels with a 4.75 inch bore and then had to get hub centric rings made to center the wheels.
You will need 3/4 inch spacers between the brake drum and inner dual on the rear. I have 2 inch spacers between the duals but could have/should have gone with 1.5 inch apacers.
You may need a spacer in front. I have 1/2 inch spacers up front and I still rub the tie rod at full right turn.
nyoffroad
722
Rochester NY
16.5 wheels are getting hard to find and dually 16.5s ... I haven't seen any of those in years. A lot of that old stuff has been crushed and melted back when scrap price was so high. Good luck, it does have a nice look.
Curtisje
697
Okinawa, Japan
16.5 Dually wheels (4.75 inch hub bore)
https://www.etrailer.com/Tires-and-Wheels/Dexstar/AM20730.html
$127 each.
2 inch rear spacer
https://www.wheeladapter.com/product/ford-chevy-truck-8-by-6-and-a-half-steel-wheel-spacer
$370
3/4 inch spacer
https://wheeladaptersusa.com/collec...-gmc-sierra-f-250-f-350?variant=5554805309471
$60
My truck came with a spacer between the duals. I had it machined down 1/4 inch at 4.75 inch to mount the front wheels. $100
I also had to get longer studs for the front. $200
Hub centric rings. $40
4 inch lift to clear the tires without cutting sheet metal.
tobyS
840
IN
Would it have been possible to use the HMMWV wheels on the front or some non-bud wheels (I have some older trailer rims that are 16.5)? Looks good.
Curtisje
697
Okinawa, Japan
But that set is to convert a SRW to a DRW. He already has a dually (I think) and he wants to mount 16.5 inch hmmwv tires.
319cssb
221
Easley SC
Correct, i have duallies on the m1028.
I am not sure if i want to lift the truck though. Have to let that idea marinade a bit.
Curtisje
697
Okinawa, Japan
cucv.jpgThis is my 1984 M1008 with hmmwv wheels and tires. I used Off Road Design zero rate 1 inch block and did a lot of trimming on the front fenders. I used Arrowcraft front axle dually adapters on both axles to get the wheels out and get the front wheels to clear everything. (The same company cucvrus referred to, great product)
The rear tires cleared with no problems.
You wouldn't need the front adapters but if you want to run 37's your going to have to either trim your fenders considerably or lift the truck, or a less aggressive combination.
