rustystud
- 3,274
- 113
- Woodinville, Washington
What?Here, this should provide some useful information.
What useful information ? Grammer ? What does that have to do with trailer lights ?Here, this should provide some useful information.
Chris, do you know who sells these older style aluminum housing lights ?Nope, not un-common. The aluminum buckets are older and quality made. The led lights is a later up-grade.
3 typos in your post. Must not have had your coffee this morning.The aluminum lights were used on everything that used tgat style of light. Not all of them had LED modules for the BO function. Ghey are still out there in quantity. The screws will corrode and sieze up. As mentioned, make sure that the seller shows pics of the screws removed and anti sieze them when you assemble them. A number of years back there was a glut of complete lenses that came out.
The last perfect person was crucified on a cross at Calvary. With that said I edited the post. I only found 2 typos. Care to share the 3rd?3 typos in your post. Must not have had your coffee this morning.
Seize not sieze (according to Google). Feel free to delete my 2 posts after correcting. Was not meant to criticize just a heads up.The last perfect person was crucified on a cross at Calvary. With that said I edited the post. I only found 2 typos. Care to share the 3rd?
Just shows you no one is perfect. I missed the 4th one.Stupid I before E except after C rule. Will fix. Since I used seize twice, wouldn't that be 4 typos?
