M105A2 Trailer Pick Up*** NOW WITH PICS***
mtnpatriot
El Paso, Texas
OK, I'm Heading to Colorado Springs to pick up my M105A2:
http://www.govliquidation.com/aucimg/photos/8892/8891142.jpg
http://www.govliquidation.com/aucimg/photos/8892/8891143.jpg
http://www.govliquidation.com/aucimg/photos/8892/8891144.jpg
http://www.govliquidation.com/aucimg/photos/8892/8891145.jpg
It was REFURBISHED in mid '06. I don't have any spare tires for it and I am going to trailer it to El Paso with my civ '06 diesel Silverado. I've got a set of mag lights, a pintle hitch, a Hi-Lift Jack, some hand tools, and a couple good prayers to ensure I get home. My question is this; If I have tire problems on the way home, can I use fix-a-flat for the tires? Additionally, can a standard repair/tire shop fix a flat on these tires? I don't have any experience with these tires.
Anyone in Colorado Springs have an extra tire & wheel they want to sell?
Angus1
Freeland,Pa
RE: M105A2 Trailer Pick Up Question(s)
the tires on those trailers are tube tires. Anybody should be albe to fix a flat.
neilhendrix
Reidsville N.C.
Lug nuts are 1 1/2 " ..Might have really good tires if there was a referb in 06 . Good luck keep us posted
mtnpatriot
El Paso, Texas
Well I bought the following to tow mine home (I got everything at etrailer.com):
Cushioned Pintle Mounting Bar - 10 Hole
Pintle Hook, Bolt-On, 10K
Magnetic Towing Light Kit, 20 ft. Long Cord
And a spare one of these (it comes with one but I bought an extra)
Pintle Hook Mounting Kit
I'm in Colorado Springs now and I'll pick it up tomorrow morning. Anyone know what spped limit I should stay under when I tow it 650 miles back to El Paso?
And THANK YOU ALL for the PM's and the info!
oifvet
9
(near) Xenia, Ohio
They track nicely. Put maximum rated pressure in those 9.00x20s and roll! Just mind your increased braking distance. You should be able to run 60 mph w/o much problem. I'm sure guys have pulled them at 65, but until you've had a few hours of, "getting to know each other" time, no need to get going too fast, too soon.
Stay to the right and enjoy a nice easy trip home.
1,827
I've .pulled home more than a few 105s behind my pickup. Once accustomed to the banging around, they are a breeze to tow. Should be a fun journey.
Srjeeper
40
NE, Pa.
Judging from the pics, I'd say the trailer is in excellent shape, so you shouldn't have any problems. Once you get rolling, stop every half hour and carefully feel the hubs to see if anythings heating up. The trailer weighs in around 2700 lbs so drive accordingly and enjoy the ride. :wink:
mtnpatriot
El Paso, Texas
Well I picked up the trailer. I met Brent13 and he helped me get her hooked up. Thanks again Brent.
As for the trailer, a couple observations:
1) She is in NEW condition. Refurbished 06/06 and only a SMALL scratch or two.
2) She is HUGE! I didn't realize just how large the M105's are. Need to rethink keeping this one or getting a smaller one.
3) Brent & I could not get the "landing leg" (not sure of the proper name) to lock in the "up" position for traveling down the highway. Ended up lashing it in place with a ratchet strap. Worked good as a simple temp-fix but need to come to a propper perm-fix if I am going to keep it. It looks like there was a 1/4" plate welded on during the refurb and it is just a hair to thick to allow the leg to lock in place. I'm thinking about taking a mini-grinder to it to take off some of the plate off.
I pick up a couple spare tires & wheels for $40. Thanksfor the intro on that one reitenger!
Any suggestions would be appreceiated.
WillWagner
3,164
Monrovia, Ca.
There is supposed to be a thrust washer between the gear and trailer tongue. If the rebuilders have two thrusts on the gear, it won't go up far enought to latch in the travel position. Nice trailer, looks new!
mtnpatriot
El Paso, Texas
Do you happen to have a pic of what it is supposed to look like? Mine won't make it past the leading ledge to allow the locking pins to engage & lock in the holes. I don't want to take a mini-grinder to it unnecessarily but I'm not sure what a correct ones looks like or how it functions.
Brent13
Colo Springs, CO
Steve,
Pictures hardly do it justice, that trailer looked brand-spankin'-new. It actually looks no bigger than a 101 in the pictures, but I know better seeing it in person. That mother is
enormous!!!! What is the actual size difference from a 101. I know it is taller, but is it both longer and wider? Anyway, glad to hear you made it home and didn't abandon the beast along the road.....
Brent
WillWagner
3,164
Monrovia, Ca.
I have an exploded view, but it is in a paper TM. I will scan this afternoon.
