Hummermark
- 31
- 28
- London uk
hi has any one changed out the 15w\40 oil from the m1070 clt-754 transmission? if so what did you use fluid wise? and how did it fair with the new fluid? would like to hear from people who work there trucks ie gcwr 50ton and above.
any tips for draining to a different fluid ie draining torque converter?
or is the 15\40 oil working fine for you with no ill effects? would be interested what miles you have done with the 15\40 I am on the fence which fluid to go with thanks.
